It is currently Wed Jul 23, 2025 9:59 pm
PostPosted: Thu Jan 10, 2008 6:28 am
I'm thinking of trying some of this stuff for binding. Anybody used it?
PostPosted: Thu Jan 10, 2008 6:29 am
Oops.
link
PostPosted: Thu Jan 10, 2008 6:46 am
what do you intend using it for?
PostPosted: Thu Jan 10, 2008 6:58 am
[QUOTE=crazymanmichael] what do you intend using it for?
Beer straws
PostPosted: Thu Jan 10, 2008 7:26 am
[QUOTE=MichaelP] [QUOTE=crazymanmichael] what do you intend using it for?
Beer straws [/QUOTE]
Yup!
Michael, your thread about surgical rubber got me thinking about this tubing to wrap the body after binding, not as a binding material as my original post may have suggested.
PostPosted: Thu Jan 10, 2008 7:36 am
I gathered as much I just having a manic day
I tried surgical tubing, Not this stuff, and it worked great. However I did like Todd showed in the other topic and taped first then used the tubing to draw in good and tight. I am trying to design a system that where I don't use tape at all and clamp with band as I work my way around.
PostPosted: Thu Jan 10, 2008 7:38 am
They make flat banding too. seems like it would be less likely to roll around as you position it. Kinda wide but easy enough to cut.
Here's a source.....
http://www.fwonline.com/lftbands.htm
Horton, MI
PostPosted: Thu Jan 10, 2008 7:58 am
Hmmm. Kirt, I hadn't thought of the bands. I even have some at home. Also, it could cover a much wider bit of binding than the tubing. Now to find out what "synthetic elastomer" means. Thanks!
